Hello All,
I have a dwg file with hatch inside, when I open the dwg file with MS V8i in my PC, it can display correctly(from file, where is the file?). But it cannot display in some workstations(filled, but nothing shows). Our workstation/MS should be same. Can anyone tell me how to let all the workstations to show the pattern? Thanks a lot.
Changsong Ling said:Can anyone tell me how to let all the workstations to show the pattern?
There could be several reasons, but I would start with View Attributes...
Check the Fill and Patterns settings on your computer and on the other computers.
Both are Same. Thanks.
The screenshot without the pattern is not showing the pattern name in properties. Are both workstations using the same workspace setup?
Not exactly same, but we don't revise related configuration, they should be same.
Or I'd like to ask the question a different way, the first picture shows "from file", which file exactly?
Thanks a lot.
Probably a cell library ie a .cel file that may be in one project but not the other?
