When I transferred my files from J to v8i, layers appeared that has nothing to do with my work. I tried to delete them but they can not because it says they are in use. How do I get rid of these layers?
They might have shared cell definition on them. Try the keyin 'delete scdefs all' to see if there are any lurking in the file then see if you can delete them.
Did you get any message here like the above?
Only other things I can think of are checking if the levels are locked? Also what is on the levels concerned the properties should tell you. Can you post an example so people can take a look?
