I am trying to view a 3D Bentley Vi8 file using Bentley Vi8 View. The original file was created with element tags, names, descriptions and other key properties. Yet, when I try to view the 3D model in Bentley View, the element properties are mostly missing except for the element level and a few graphics properties. How can I find/view the property information from the original file? Please note the original file was created using Bentley OpenPlant Modeler.
Hi Alex,
Alex Henry said:using Bentley Vi8 View
Please follow communities best practices and always specify product version exactly using product full name or build number.
I do not think you use "just" Bentley View V8i, which is the name of the original version released many years ago, but maybe some newer version like Bentley View V8i (SELECTseries 4)?
Alex Henry said:The original file was created with element tags, names, descriptions and other key properties.
I do not know OpenPlant Modeler in detail, but I assume the information are specific to OPM and are stored specifically in DGN V8 file, because the format does not know such properties (but it knows standard properties like level etc.).
Alex Henry said:How can I find/view the property information from the original file?
What you can try:
I also recommend to ask in OpenPlant forum, because it's OPM issue, not MicroStation or Bentley View and maybe other OPM users have discussed / solved this issue already.
Also my feeling is that recommended product to access 3D data is not Bentley View, but Navigator.
With regards,
Jan
