Using 'place note' to place text with a box around the text. The note places correctly but then after clicking the next command, the box rotates 45 degrees. The text does not rotate, nor does the leader... just the box. What is causing this to occur? Using Connect 10.1200.40
Has this issue been resolved. I'm using MicroStation Connect Update 13 and am still getting this issue. When I place text with a box around it, it first appears fine but then when you attempt to move or edit the text the box becomes a rotated box and appears like a diamond shape.
Its the same problem as Lance Kitchens had back in June 2019.
Why has this not been addressed in Update 13?
Anyone?
Alan
Looks like this might have been fixed in R14
Answer Verified By: Melissa Hook
Yes, this issue has been addressed in Update 14
