Microstation CONNECT Edition Dimension Constraint
Is there a way to control the movement of a constrained object (Dimensional) ? so it will lengthen to the right or to the left if i change the variable. in the screenshot below the object lengthens to the left when i change the variable. is it possible to control this so it will lengthen to the right if i change the variable? thanks.
Parents Reply Children
