Using MicroStation, I'm just been trying to translate some simple DWGs to dgns using CE 12 Batch Convertor, it keeps hanging halfway.
Open the same set in SS10 and it rips through them! surely it should the 64-bit application that does that?
Thank you for letting us know! We have discovered a DWG-specific issue related to legacy ACIS solids, so perhaps this is the cause. Is it possible the files contain these? Would you be willing to share a sample file with us so that we can test it?
Makai SmithDirector, Product ManagementMicroStation Product LineBentley Systems, Inc.
Ah, thanks, Please let us all know if there is a work around for these rouge AEC Objects in Connect that slow it down.How can I send you a file directly?
I have the same problem when using the command line for the batch convert
C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\msbatch batchconvert C:\{myfolder}\BatchConvert.bcnv
I have tried both ms10130101en_updt13 and ms101400109en_updt14
Kind regards Gavin
The above issue was from nearly a year ago and for an older version to what you are mentioning here. It may not necessarily be related. You might like to post your issue into the main discussion as a new question to be investigated. It would be helpful if you could supply example files, error logs, screen captures to help explain and try to replicate your issue.
