Connect Edition Update 12 - Version 10.12.00.40
I have numerous circles in a file, I place them all in a selection set and use the 'export coordinates' tool to generate a .txt file with the coordinates. A point number is generated for each circle. How can I label the circles in the file with the point number that has been generated?
Lance Kitchens said:How can I label the circles in the file with the point number that has been generated?
Search this Forum for terms such as XYZ Import or Text Import.
Update, the point numbers are labeled. They were placed on the default level and I had that level turned off.
Yet another defect they'll fix in version Release 9,578
