Layers & Colors to Levels & Colors
I am using MicroStation v8i SS2.
I am referencing an AutoCAD file into my dgn file, and have set the layers in AutoCAD to be all "color-by-layer".  When I reference into MicroStation, select Merge to Master in reference dialog, all my layers and colors reset to "Default" and a white color.  If I set all my layers in AutoCAD as color by object, instead of "by layer", then I retain my colors from AutoCAD when Merge to Master, but the layers still revert to the Default level in MicroStation.  Is there a way to preserve my layers and colors from AutoCAD?
