I'm having an issue with a couple of my tools. For example, normally when I hit the scale button this box would typically come up and I could choose active scale, two point scale or three point scale, but now that box is not popping up. I restarted my program and computer and still nothing. How do I get that box back? Note: it is not hidden behind something else, I checked and closed everything else to be sure.
Kristina Crimmins said:I'm having an issue
In which version (e.g. v10.x.y.z) of MicroStation, or other product?
Hi Kristina,
Are you using multi-monitor displays? It sometimes has a habit of opening up off-screen sometimes (not sure why). Have you tried the Popset dialog recentre function to reposition it (there are a few posts here about it)?
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
in addition to what mark posted
try control & space bar together... does the power selector pop where you want it ?
Lorys
See also related Wiki https://communities.bentley.com/products/microstation/w/microstation__wiki/8977/restore-tool-settings-dialog
Carl Myhill
Technical Support Engineer
Bentley Systems
