We have a dwg which contains callouts however when opening the dwg in MicroStation, these callouts are rotated and do not look like they should. Anyone seen this before and how do we resolve this?
Any advise will be much appreciated.
See image attached that illustrates the issue
Which version of MicroStation are you using?
MaryB
Using MicroStation CONNECT 10.10.00.23
That's a couple of versions out of date and Bentley are due to release U13 imminently. Your best best is probably to submit a service request with a sample so they can test or try the latest version to see if it has been fixed.
Hi Duncan, don't think this answers the question because it looks like the issue has been raised a few times. I just saw a similar query raised 4 years ago. I'll have to assume that Bentley may not consider this an important issue to look into :-(
