I have been trying to make my hidden line visible but ended up with no results. Here are the view in 2D after doing sheeting.
It was supposed to have hidden line as picture below.
Hoping someone can help me with this
Would you be able to provide further details regarding the version of MicroStation CONNECT Edition you are using. Also, what are you mean by a "Hidden Line"? Is this a hidden line file? Is this something performed visually? Is the file attached as a reference? Maybe you could supply an example file so we can try to replicate your issue.
I use the Microstation Connect Edition Update 11 version 10.11.0.36. If u can see in the picture below, (transparent:modelling view) there are also solid that is inside the model. So when i tried to make a sheeting of the side view of the model, hidden lines of the solid that are inside of the model doesnt appear. It just shows the model without any information of the solid inside the model.
Below is how my sheeting appear
Sorry, Faris, but this is still difficult to understand. You have design models with a 3D objects which you are producing sections of into a sheet model. This appear to have Cached Visible Edges defined but I cannot figure out much beyond this. It would definitely be useful for you to supply the design file for us to look at. If you're concerned the file(s) can be provided via our Secure Upload.
https://communities.bentley.com/help/w/be_communities_help/7079/communities-secure-file-upload
Changing your Visible Edges setting from Cached to Dynamic will make these hidden lines display.
