Hi all. As mentioned in the title, i am facing an issue when i am trying to rotate different variations of parametric tanks at the same time. I get the error message that some constraints changed the outcome of the commend. The exact wording reads:
"Constraint or dimension has altered result of manipulation."
The problem is not consistent. It appears more frequently with more placed parametric tanks.I do not have any approach how to solve the problem.
For reproducing purposes the file with the parametric cell is attached.
I do appreciate all of your answers. Thanks in advance.
Parametric Tank.dgn
Hi Christopher,
Could you please let us know which MicroStation build you are using? I placed 30 parametric cells(with different variations) using your shared dgn file, but could not reproduce the issue you mentioned when rotating.
Grace
Hi Grace Ma,
thanks a lot for your fast reply. After i read your comment a colleague of mine tested the parametric tanks as well. We noticed that a variation of the height leads to the mentioned error. You can still rotate a single tank with adjusted height but not together with a second one with different height. Can you confirm this behavior? Thanks again.
I am using the MicroStation CONNECT Edition Update 11 - Version 10.11.00.36.
Thanks for the further info. The adjusted height info you mentioned is very useful, I'm able to reproduce the problem now and have reported a defect 1039083 for it. We'll do further investigation to figure out why this happens.
Just want to let you know, we have fixed the rotate issue you reported and the fix will be included in coming update 14 build.
Hi Grace,
thanks for solving the problem and letting me know.
