could you please for changing level names for multiple files at once.
Create a batch process with the keyin below in the command file
'Level Set Name OldName NewName'
Should work in V8i & Connect
i am selected three file and run. its not working
What's not working?
How are you selecting the files?
Have you tried the keyin on one file first?
Are you using batch process?
What version of Microstation are you using?
A screenshot would help.
i am using Microstation V8i(SELECTseries -2)-Version 08.11.07.443
