DGN files opening in Microstation high security from projectWise and from downloaded location.
I have checked the shortcut target and it does only point to Microstation and projectwise associations seems to be fine.
Any suggestions, what could be wrong here?
what version of MicroStation? And how are you opening files, From ProjectWise from file explorer. MicroStation does have two icons, one is regular MicroStation and the other is high security .
microstation version is 8.11.9.459.
we have some files on desktop e.g. and it is opening in microstation. I even remapped to open with microstation (ustation.exe).
How are you looking at File Association within PW? Are you right-clicking on a file in PW and selecting Open With and setting ustation.exe as the default? If so, I have seen some issues with that not being honored. We actually had to go into PW tools menu and set it in there. Make sure you set Select an Association View to User Association.
Power InRoads v8i V08.11.07.615
Microstation CONNECT U13 10.13.01.01
ORD CONNECT 2019 Release 2 U7 10.07.03.18
ProjectWise 10.00.03.217
it was done via Tools-? Associations-> Programs-> User associations.
