On Friday all was running good on MicroStation Connect Edition 11, then around 2:30 when I try to reference in a file it locks up and I had to control-alt-delete to get out of MicroStation. I try again this morning and still locking up when I try to reference in a file, its happening to all my drawings.
thanks
I would make a new file from your seed file. Reference your troubled file into it and merge this troubled file into the new file. You may have some corruption in your file. This will help eliminate the corruption.
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
Ok I will try that, thanks
that didn't work.
So you can't reference any drawings into the one file or you can't reference any files to any other file?
any drawing I open I can not reference a file into them, it locks up when I hit reference.
