In v8i a user can utilize the INSERT key on the keyboard so that her text will be overwritten with the correct text - without the need to highlight. In CONNECT the insert command is not working as it should.
She usually leaves her Num Lock off and utilizes the 0. I had never heard of that particular shortcut but that is what she has done for years. It won't work in CONNECT. Neither does utilizing the Insert key on the keyboard.
Does anyone else have this problem? Does anyone know the fix? Thanks
MicroStation CONNECT Update 12 - Version 10.12.00.40
I can't find what I thought I saw.
If nobody else can help with this, you may want to file a Service Ticket with Bentley Support. They can help you find the fix, or let you know if it's an actual bug.
MaryB
I think this may be the post Mary was looking for.
Defect # 539411 approved for release
