CE: Turning on/off an element in a parametric cell
Hello guys,
I created a parametric cell which is specifically a sign gantry with a number of signs inside, what i would like to do is to assign a variable that would turn off/hide a certain number of signs according to the assigned variable, is this feature available on the current version of microstation CE? Im using update 12.
I can do a little trick for now by making the assigned dimensions of a specific sign really small so it wont be visible unless you zoom it to a maximum, but the problem is sometimes it messes up the 2D and 3D constraints that were put inside it.
I hope this can be filed as an enhancement or additional feature, same as visibility parameters in revit.
Cheers.
  • Sorry for the delay in response to your issue. It would be helpful if you could provide example design files, screen captures etc. to help explain your issue for it to be raised as a possible Enhancement. I had located Enhancement # 1064166:Want ability to Isolate Text within a Parametric Cell to Turn ON/OFF as needed per sheet placed, which may be similar but would need to test your case with examples.
    Andrew Bell
    Technical Support
    Bentley Systems
