Updating Tagset from Projectwise
I'm struggling with the integration between Projectwise and Microstation in the intent to manage our title block informations in the sheet drawing from Projectwise.
The general settings has work out fine. My title block works fine and it updates as a breeze when testing the Microstation/Projectwise connection directly in the title block file .... BUT....
When inserting the title block as a reference into a new drawing, copying the tagset from the title block reference into the sheet drawing nothing seems to work. No updating from the properties connected to the active sheet file.
The tagset contains the information from title block eventhough the tagset is copied into sheet file and I can't update it with the MS command "Titleblock updatenow"
A link between the tagset and Projectwise seems to be lost when i'm copying the tagset from the title block reference into the sheet drawing.
Has anyone experienced the same problem and solved it ?
Kind regards
Ole Bro
Parents Reply
  • Indeed ...
    Something had happened with the first DGN file while i was testing the title block integration. I do not know what. I spent hours checking and testing the integration. Nothing was working.
    Then I filed my issue here and turned to some other stuff. By coincidence  I returned to title block once again, this time  with with a fresh and empty DGN file. Inserted the reference, copied the tag set into the file, updated the tag set with the key-in command "Titleblock Updatenow"
    And it worked.
    I did nothing but skipping my testing file and moved to a new fresh one. That's why I replied with "The problem solved by itself"
    ORD Connect:10.08.01.033
    MS Connect: 10.14.02.01
    Projectwise: 10.00.03.49
