I've just started using Tables and they're terrific but I have found a little glitch. When I break the table and set its 'Sub Table Spacing' it doesn't follow annotation scaling. Has anyone else come across this or is there something I'm missing? I'm fairly confident that it's a glitch because the break height does scale up
Creation"
Placed:
ilija
Which version are you working in?
I've tried to replicate the issue but have not been able to. Is it possible to share the file where this is occurring?
Hi David,
Microstation CONNECT Edition Update 12 - Version 10.12.00.40
IM_table_seed.dgnlib
Hi IIija Minic,
I am able to reproduce issue with the table placed in the attache dfile but not if I place a new table in the same file. Can you share how did you created this table, From Excel file or From Report or by placing Empty table?
Mahendra
Hi Mahendra,
it was done by placing it into a new file which has a different annotation scale. The vertical/break value changes according to the annotation scale (so it will multiply by 500, for example) but the horizontal doesn't (it stays at 140mm or whatever it was set at)
I have reported Defect 1049462 for this issue.
