I currently am using microstation v8i ss4 and I have my drawing setup to a coordinate system. My drawing consist of a bunch of lines and curves.
What I would like to know is there a fast way to get the coordinates of all the coordinates of the begin of line, bc and ec and end of lines. I know I can move the cursor over the points but this will be very time consuming.
Can the coordinates be placed in a table where I might be able to print it out.
Steve Smith said: I would like to know is there a way to get the coordinates of the begin of line, bc and ec and end of lines
Visual Basic for Applications (VBA) could do that. You'll have to write some VBA code, or pay someone to write it for you.
Before you start, you must decide the format of the data you write. XML is a good candidate, because it can accommodate variable-length records (such as a set of line vertices) and 3D data points easily. On the other hand, a Comma-Separated-Value (CSV) list would be a poor choice, because it can't easily represent variable-length records.
Why do you want those data? Most people like to draw lines and then print them. Knowing the coordinate values is not always useful.
Hi Steve,
the answer is yes, if you have someone who could write you a little VBA Program. This VBA could write alle coordinates to a CSV / Excel file.
Mit freundlichen Grüßen / Best regards Volker Hüfner
| AB_DATE Engineering Software | ab-date.de |
Steve Smith said: currently am using microstation v8i ss4 and I have my drawing setup to a coordinate system. My drawing consist of a bunch of lines and curves. What I would like to know is there a fast way to get the coordinates of all the coordinates of the begin of line, bc and ec and end of lines. I know I can move the cursor over the points but this will be very time consuming. Can the coordinates be placed in a table where I might be able to print it out
there is a way right now without vba set your active level to an new name and set your text to cc and a easy to read height, now turn off everything except the objects you want xyz for now run the export coordinates xyz tool to a csv file in the settings for this tool you have the option to label the points with a number it will also put this id number into your csv table.. and you can use a fence to capture all or a selection.. then open the csv with excel or note pad and you can modify this to have nice headings and import the table back as excel embedded and it will reflect the numbers... you may have edit out some points if some lines have extra vertices or like squares the start and end are duplicated .. but generally works pretty well, the annotations are in the order the line work objects were placed.. but if your happy that its done ... if you want the arcs separate from the lines then only select the arcs run the tool and then only select the linestrings and run the tool again and either use append or new csv...
Let me know if you need more help on this I use it a lot.
Lorys
Lorys said:export coordinates xyz tool
This is also a good possibility. I learned something new. And found even some interesting article here: How to export coordinates for the center point of circles in the design file?
volker has link to show you how to use the xyz tool I mentioned but it will work for arc and strings and it will add the centres of the arcs but as they are labelled you can see which to remove from your table or change the text to not show arc centres...
much easier than creating and debugging vba when the tool already exists .. yes less powerful but you can use it right away... and it lets you use excel which most modern office workers can already do lots of easy clever stuff... and simple msnt pastes special to make the table embedded with excel formatting looks really good in microstation let me know how this works out for you...
communities.bentley.com/.../how-to-export-coordinates-for-the-center-point-of-circles-in-the-design-file
