Is it possible to measure area of a shape/associative region in report by named boundary?
ORD Update 7 uses Microstation CE Update 12 as it's PowerPlatform
Mark
Lorys said:work around would be to create a tag set and tag the said objects then you can create tag report or in CE create items and use that for reporting
With MicroStation CONNECT you need neither tags nor Item Types to report on element data. Andrew's description shows how to write an Area Report, and my article about Area Reports tells much the same story (with the benefit of a DGN example).
Lorys said:AreaAnnotator™
Thanks for the mention! AreaAnnotator CONNECT Edition has been available for some time. AreaAnnotator V8i is still available.
Lorys said: they were free
AreaAnnotator V8i remains freeware. AreaAnnotator CONNECT Edition includes several new features (e.g. alternative measurement units) and requires purchase of a license.
