Is there a list somewhere of MicroStation elements that do not convert to AutoCAD? Line style problems, fonts, leaders, annotation scale, cells, etc.
not sure of a list but look up the help under save as DWG and you will see all the different settings under the options also good search keyin
" sharing DGN and DWG data" yielded a lot of useful information to consider....
But generally what happens or you need to consider
DGN linestyles 0-8 are supported all custom linestyles are not ( unless they are already acad ones)
Cell convert to blocks
non truetype fonts ie Bentley fonts are not supported and you need the create shx option so the non true types are converted and acad can then read thenm but you have to allow the acader be able to find them so I like to send them to the same place the dwgs are ...
for dims here is option for dims to save the active dims settings and create inline leaders if you wan them...
entity mapping has a lot of things listed
and under advance there re options to drop things
and create true color from DGN colour numbers.... but this may not be compatible with dwg print settings
construction elements to const layer
there is loads of settings .. you need to look at them all maybe print the help and come up with your own setting for different types of dwgs needed....
Lorys
Answer Verified By: Chuck K.
you might want to consider using DWG Workmode:
https://communities.bentley.com/products/microstation/w/microstation__wiki/2971/using-the-dwg-work-mode-in-microstation-v8-cs
https://communities.bentley.com/products/microstation/w/microstation__wiki/8930/workmodes-dgndwg
Timothy Hickman
Main: 877 627 3772|
Best is to stick with DWG format only in case of multi-format environment then you will avoid any conversion problems.
What we do:
Thanks everyone. I have used DWG mode but was just looking for a solid list of items that don't translate.
