I am using the remap functionality in the save-as dialog to remap levels and I want to also change the default byLevel attributes. In the Levels tab of the level mapping table I am specifying values for ByLevelColor,ByLevelWeight and ByLevelStyle, however none of these get changed after opening the new file, only the level itself is being changed.
Which version of the software are you using? Different versions may have different "quirks".
MaryB
Connect update 12
OK. I can't help with Connect. Hopefully someone will be along shortly.
Hi Rayjoslyn,
Can you send me the dataset where you see the issue with remapping the levels?
Connie Wallace
remap.zip
Here are the files
