Connect r13. I like to keep the ribbon out of site so I click the little arrow up by the Search Ribbon box. Every time I change models the thing unhides. Am I doing something wrong or is there a new setting?
The first item to check would be whether you have Saved Settings and whether you have full Read+Write permissions to the User Preference File (UPF).
https://communities.bentley.com/products/microstation/w/microstation__wiki/13452/troubleshooting-user-preferences-issues
Not sure if this is a new preference but the "Expand on Mouse-Over" may be related to what you are asking here.
Thanks for the reply Andrew. But none helped. Deleted my UPF (never a bad idea), but I did have full RWED permissions for that. Mouse over on/off no help as well. Attached is a new file, created a model for testing, does the same thing. Not for you?
Base(N).dgn
Hi Bob,
I tried your file but the Ribbon remains minimized when switching between the two files when I double click on the different Models in the Models dialog. Can you try to restore the defaults rather than just deleting the upf file?
https://communities.bentley.com/communities/other_communities/askinga/w/askinga/3320/quickly-restore-the-defaults-with-a-command-line-switch
Please let me know if that works for you.
Dan
Answer Verified By: Bob Rayner
Remains minimised for me too. CE U13
Thanks folks, thought it might just be me. Wouldn't deleting Personal.upf restore defaults? I just loaded r13 last Friday.
I'll read the link
