I see that in Connect is not possible to cut elements in illustration mode when you click on part that is invisible
In v8 you can select when you expect elements is…. I don't know if this is clear due my English.
Could you also share the dgn file. Just the wall and the profile. It will help to reproduce it at our end
Hi Nilesh
Here is a dgn file and jpg
I think that is something in settings to prevent illustration mode not click something not visible...
In transparent mode you can cut. But i remember that in v8 it works in illustration mode too . For example i can't cut something behind window / transparent material too /
test cut.dgn
Hi Martin,
I am able to do this on my solids, please check attached DGN showing the same and please do let me know in case if I am missing on something
DineshTest5.dgn
Btw there is a problem in Connect saving illustration mode jpg - in my file there is a green lines and text. Can you
investigate this, too
Dinesh - check my answer to Nilesh.
Are you shure that you click cutting profile inside a wall ? Not on the visible edge ?
You can't even select in illustration mode by invisible part - maybe there is only something in Preferences
