Hi, I need to switch off several levels in master file using key-in for doing editing work, can anyone suggest the key-in which can be used or links which is already published and what will be the limitation in key inThanks in advance
There are plenty of good examples in the Askinga section.
This link shows how to turn on/off level filters but works the same for level names
/Krister
Owner consultant at Surell Consulting AB
