Apparently in Connect update 13 labels do not update when I change Item properties. In older versions this worked correctly.
See attached screenshot. When I change the item property "01-lokaalnaam" from "test" tot "test5" this is not reflected in the attached label.
This makes Update 13 completely worhtless. I have to uninstall it from the workstations on which it is already installed.
I just hope I missed something but I am afraid I did not.
15 plan tweede verdieping.dgn
Luc Dierick
Belgium
Hi Luc,
Luc Dierick said:I just hope I missed something but I am afraid I did not.
It seems unfortunately you do not miss anything :-(
I can confirm the problem on my MicroStation CE Update 13 installation, whereas Update 11 installed on another notebook works as expected.
Unforutnately I am not aware of "label update key-in" similar to e.g. text fields update.
Luc Dierick said:This makes Update 13 completely worhtless. I have to uninstall it from the workstations on which it is already installed.
I agree, it's critical bug. And very dangerous. I will have to discuss with my customers whether they use Labels + ItemTypes in their projects.
Bentley, you recommend to replace tags by ItemTypes + Labels combination, so it's crucial MicroStation feature. How you can let go such bug to public release? Did you give up quality control and software testing?
Jan
Luc Dierick said:When I change the item property "01-lokaalnaam" from "test" tot "test5" this is not reflected in the attached label
Are those text fields part of text elements inside a cell? That is, is 'label' a synonym for 'cell'?
Jan Šlegr said:Bentley, you recommend to replace tags by ItemTypes + Labels combination, so it's crucial MicroStation feature
I agree. Is this related to the problem I posted about text fields in cells? That is supposed to have been fixed for Update 13.
Jon Summers said:Is this related to the problem I posted about text fields in cells?
I do not think so, the label is just label, not cell. And it works in U11 (have no U12 installed to test it).
Jan Šlegr said: the label is just label, not cell
It's a cell!
See Carl Myhill response in this thread.
We need a Service Ticket for the problem - and I hope, the Product Managers find a way to solve this before U14...
A Report shows the Changes in your Items correct, so they are changed, but not displayed.
Also: The Key-In PLACE LABEL gives "Command not defined for this Application" in U13.
