Is it possible to make a local style permanent so it can be imported into any project?
Best option would be to create a dgnlib to store and load the desired Dimension Styles. See the following:
https://communities.bentley.com/products/microstation/w/microstation__wiki/16830/how-to-import-dim-styles-from-a-file
Answer Verified By: Chad Errey
Hi Chad,
If your problem has been resolved by the reply from David then you can close this post by clicking on 'Verified Answer' button.
Thanks for posting,
Manoj
