MicroStation CONNECT Edition Update 13 - Version 10.13.00.48
When editing text, I can not accept the edit and select the next text string. I have to select the text, edit it, then accept it and then I lose the edit text command and are forced to select the command from the ribbon (toolbox). This occurs for every text line I edit. Basically it has forced another step to editing text. Was this a change in the latest update, or am I missing a toggle somewhere in preferences. FYI, I have 4 other computers that have not had the Update 13 installed and these computers do not have the same problem.
It's a bug in U13 and has already been filed as a defect.
