Hi all,
I'm working with Microstation V8i SelectSeries 4. I work in a 3D stereo environment with aerial imagery. I'm trying to figure out if I can use the mesh project tool to drape data points to the mesh I created. I can get the desired result with line segments but not with single data points. Any help/information is appreciated.
It may depend on what type of elements these "single data points" are. Would they be points, cells, zero length line strings? Maybe if you could provide an example file, along with the workflow and screen captures, you are using when draping line segments on this mesh.
Hi Steve,
You could try using the command MOVE TO CONTACT
Regards,Ron
