[v8i] Paging File Use Along side 'Lock Pages in Memory'
Dear Forum,
On my windows 10 laptop, with MS v8i SS3 and 32gbs of memory, we all know that i run out of memory when viewing large objects as when MS reaches roughly 3GBS it crashes. I have invoked Lock Pages to Memory, but id like to understand how the Windows 10 paging file can help, what size it should be set to, and does this and the Resource Cache setting in MS Preferences, work together?
if my Resource Cache is set to more than 3GBS, is this a help or hinderance? Shoudl it be 3GBs as thats all its able to utilise? Does having it larger than 3GBs simply allow MS rto crash more easily?
Does Windows paging affect Resource Cache at all? Is there an optimum set up which allows the most efficient way of working?
Any yes im fully aware that Connect does a far bettter job of Memory Management, but the tools i am using arent written for Connect..... yet...!
