How to break the dimension like autocad
Rajesh
Use the Drop tool. The shortcut is 61. then within the tool options, check the dimension so that this is dropped
Ian
If you are referring to the break for drafting purposes but leave it as a dimension this functionality doesn't exist in Bentley DGN based products.
~HTH
John.
yep
ae you also wanting to put the break zz in the dimension... then go to askinga there is a free mdl utilities from a Bentley employ forget his name but lets yo do a lot of extra cool stuff like stairs in profile tool, fake custom line with text like -- OHP----, break line parallel line symbol etc worth a look comes in handy every now and again..
Lorys
Answer Verified By: Rajesh Kanniyppan
Its not Break the dimension its exploding the dimension i want know about the break dimension like auto cad
The tool was called MSM Tools for V8. It will also run on V8i SELECTseries though. It can be found here.
https://communities.bentley.com/communities/other_communities/askinga/w/askinga/1240/msm-tools-for-microstation-v8
Ivo Blaauw= = = = = = = = = = = = =Look what the CAD dragged in...
