MicroStation V8i crashes when I work with large dataset
When I editing contours (large dataset) created and connected to loaded las-points (large dataset, TerraScan) and surfacemodel (large dataset, TerraModeler) MicroStation V8i crashes after about 30 changes of these contours. There is no warning window showing, the program just shut down immediately. This also happandes when I try MicroStation CONNECT Edition.
(I work with MDL Application TerraScan and TerraModeler to do this kind of work)
Is anyone familiar with this or know what I could do for avoid this to happend?
Could it be someting with the internal memory? How do I fix that?
Kind regards,
Elin Skoog
Parents Reply Children
