I'm trying to install MicroStation V8i (SS3) on a server without an internet connection but I can't. I can check out a license and place it in the correct folder but I need to install it first! I have done this before, in fact we already have the same version of MS on another server and it has a checker out license but I can't remember how we did it!
ThanksPaul
Hi Paul,Please note that support for earlier SelectSeries applications will end in January 1st, 2020:https://www.bentley.com/en/desktop-applications
As for the issue, installer needs internet connection to download prerequisites. In your case you should create deployment image on a machine with internet connection and you will be able to install it on the machine without internet. You can read about it at the bottom of the article or in MicroStation ReadMe file:https://communities.bentley.com/products/microstation/w/microstation__wiki/4170/installing-microstation-v8i-silentlyRegards,Robert
Is mise,
Paul Carroll
