In Microstation V8i, you can use the "Extend Line" tool to extend a line to length of zero (start point = end point). In Microstation CE (Update 13.1), when I use the "Extend Line" tool and snap to the start point and accept, nothing happens. The command is ignored. Out of curiosity, I did a fence-stretch of a line, and was able to reduce it to zero length.
Is there any reason that the Extend Line tool in Microstation CE does not allow zero length lines, like the function in V8i?
--Thanks,--Robert
Defect # 1059729 has been raised for this issue. Not sure why they would remove this capability but still allow it to work with the fence stretch tool.
Answer Verified By: RobertArnold
Thanks Andrew.
--Robert
