I have a question but zero answers,
Do u guys know if it's possible to create a mesh from the given point cloud?
And if yes..
Is it possible to upsample that mesh by... inserting extra triangles/digits in between existing ones?
Thank you
Julian
FYI:
A better place to post a question like yours would bethe ContextCapture | Descartes | Pointools Forum
Regards,Ron
haven't tested it on point cloud directly, but there is an option to create mesh from points - available in both CE and SS4
as for your second question, there is a tool to decimate mesh (reduce number of vertices / edges) and another one to subdivide it (add additional vertices/edges to smooth it) - available in MS CE
/pt
Answer Verified By: Julian Olszewski
You can follow the instructions in the article below in creating a mesh from a point cloud:
https://communities.bentley.com/products/microstation/w/microstation__wiki/16917/how-to-generate-a-surface-mesh-from-a-point-cloud
as far as upsampling perhaps the "subdivision mesh" tool would accomplish this.
Thank you Peter,
Do u know name of this tool? Thank you
J
Thanks David,
This almost helped, now I need to work out how to upsample that tin,
Once again meega thanks
