Unable to attached .DGNLIB Library file to my System Bentley microstation. File created by one of my teammate and He shared with everyone to attach in their System
Hi Sir
I am Sachin Kumar. I am using Bentley Microstation V8i ( SELECT series 10). One of my friend in my organization created a (.Dgnlib ) Library file for ( Metallurgy Levels, Equipment Boxes, Multilevel Colors ) for P&IDs Drawing. He shared that file to use for everyone. But, I am not able to attach that file in my system folder. He asked me to place that file in my system at the following path
C:\Program Files (x86)\Bentley\MicroStation V8i (SELECTseries)\MicroStation\mdlsys\required
Can You please help to resolve this issue. How can i attach that library file to my machine to use in Microstation work
Sachin Kumar
Parents Reply
  • The mulitlines could be in an other separate dgnlib, and  " He"  has all these various dgnlibs  pathed via his workspace config..
    you should get your  cad manager to help you create a workspace and files that are the same for all but failing that you need to copy all the relevant dgn libs to the dgn libs folder and let your workspace config  find them,  the later is only  good if you work off line the former is when you work at work online with the server set up so files are central not on your pc ...
    Lorys
    click link to PM me
