When I try to use the Select By Attributes dialog to select Text I cannot add anything the settings box eg Font; Justification or String. I went back to my old V8i and it is working fine there. Any ideas anyone? Thank you.
I just went to google because I discovered I had this problem.
and one of the first links was the below link, from 2015
https://communities.bentley.com/products/microstation/f/microstation-forum/112982/select-by-attributes-string-input-field-for-text-and-textnodes-greyed-out-connect
Regretebly examples like this is the reason why no one bothers reporting errors.
This is a know error from as far back as 2015 and still present.
It was and is OK in V8i on my system at least Emil. The problem is in the CONNECT edition and I have found one or two other flaky problems with it as well that are probably the subject of other threads.
