MicroStation V8i Version 08.11.09.829 is not displaying the same Word Processor Font on all computers. Attached are screen captures of the same text from the same DGN file opened on two different computers. Both MicroStation sessions were opened using the same workspace and same user preferences. The RSC font "TXLEROY" looks more like the font displayed in the second image. Both computers used to display the font as seen in the second image. How can we get both computers to display the font correctly?
As this appears to be a custom Bentley RSC type of font it may be related to the operation in MicroStation V8i where a temporary True Type Font (TTF) is created.
https://communities.bentley.com/products/microstation/f/microstation-forum/181556/ttf-text-font-for-leroy-microstation-font/529223#529223
Have a look in the "GeneratedTTFonts" folder in the temp area: $(MS_TMP)\GeneratedTTFonts
They may find these temporary TTF fonts for the custom RSC font. If you delete this TTF it will be recreated the next time MicroStation is opened.
Answer Verified By: Trent Rickman
The generated ttf file had nothing in it. We deleted the generated ttf from the temporary folder and replaced it with a generated ttf file from another computer. All of the correct fonts and symbols appear correctly now. Thank you so much!
