Please find attached 2 sample files. 1 from SS4 and 1 from 13.1. For some reason step file import doesn't work properly in U13 compared to SS4. Can that be looked at?
Best regards,
Tuan Le
ss4_import.dgn
u13_import.dgn
step.zip
SR raised 7000978107
Working on your issue to see what might be the cause of this discrepancy between the two versions.
Thanks Andrew.
Defect 1062126:[Regression][From Update12]STEP Import is not importing solids at correct location
I will link your SR # 7000978107 to this Defect.
Thanks Andrew. Does that mean U12 is the version to go back to if I want to work with step files?
