Why in the Connect edition no element & Edit in the Menu?
Can you upload a screenshot with your MicroStation Connect Edition open? The element selection tool is in the Home tab of the ribbon, any edit tools that you might want to use will can accessed by typing "edit" in the search field in the top right corner. Also, if you don't like the ribbon, you can turn on the V8i task menu
Hi Soon,
there has been new ribbon-based interface implemented in MicroStation CONNECT Edition, please see more information in the following video:
https://www.youtube.com/watch?v=1BwdkOG7WM4
If you are looking for a specific tool, the Search functionality is very handy:
https://communities.bentley.com/products/microstation/w/microstation__wiki/27894/how-to-easily-find-any-tool-in-microstation-connect-edition
Best regards,
Andrea
