MicroStation Connect Publish imodel version keyin
MicroStation Connect Update 13
I am trying to control the version of the .imodel version being published with a script to 1.6 and not 2.0. It looks like the settings file I created and that is loaded is not supporting the imodel version output setting. Anyone have any ideas or solution for this issue before I file a ticket?
  • If you browse to the ITG directory  C:\Program Files\Bentley\ItgDgnDbImporter 1.5\ you will find the Bentley_DgnDb_iModel_Importer_2.0.pdf ReadMe for similar details. Hope that helps. Thanks
    This is a test
  • defect has been filed against this issue in MicroStation.
    Defect Report 799669.
    Now to focus more on the imodel importer. I have the help doc but having issues getting it to successfully pull, publish and push back into ProjectWise. Filing a ticket for more assistance since the script does not provide any feedback on error handling or success.
  • Dan,
    Thanks for info. If I could control anything since the settings file is not honoring the .imodel version, vba would be my next goto since my process is completely written in vba with calls to keyins but my understanding/research is showing me that I have no way to send the command into the publish app and control it. I do not use the SDK so I do not have access to call the api for the importer without getting a coder which in the long run may be what happens. Not sure yet. In the meantime I am playing with the importer via the command line but am unsuccessful in reaching into ProjectWise successfully. I am not getting errors but it is also not publishing anything. I will be filing a ticket on this task for more help.
    With that said, I ended up filing a ticket since this subject is a hot item on our end due to our PW Automation process is failing. In short, I have written some vba being executed via the ProjectWise command console but the version issue control is missing. A MicroStation defect was filed today on this regarding this. Defect Report 799669.
  • I am having problems getting the console to actually work in ProjectWise. I can get it to run locally but nothing in ProjectWise. The documentation helps with the switches but no examples are provided for either the local or a ProjectWise workflow.
  • The Bentley DgnDb iModel Importer converts DGN V8-format packaged i-models (.i.dgn) into the compressed DgnDb-format or BIM-format (.imodel) iModels. So in technical terms it imports all the contents of the DGN into a fresh .imodel (Sqlite DgnDb file), hence this naming convention was used. Also in the Publish i-model(s) Dialog Help chapter, there is a tip referring to same .pdf file. The location of the .pdf was removed because there were three version of DgnDb Importers and mentioning different versions simultaneously were not possible. Tip: To learn more about creating .imodels using the Bentley DgnDb iModel Importer or other supported file-formats conversions in batch mode, refer to the help in .pdf file available in its installation directory.
    This is a test
