I'm attempting to design a Table. I've defined some Text Styles for Title, Header, Body and Footer rows. Each style has a different justification. However, the table ignores the style justification and looks like it was specified as top left each time.
Text in the table adopts all the Text Style properties except for justification. That is, colour, font, size etc. appear as expected, but the text is improperly aligned.
Did you try looking at the cell Properties of the Table? There is a justification field that can be modified.
Well, that's an option. The table rows adopt other properties of the assigned text style (e.g. font, size, colour etc.), so why doesn't it adopt the justification?
It looks like Defect # 1056151 has previously been raised for this issue. If you wanted to get updates for this please raise a new Service Request which we can link to it. Looks like it has been approved for a future release but not sure whether Update 14 or 15.
Answer Verified By: Jon Summers
Which version (e.g. v10.x.y.z) of MicroStation are you using?
~HTH
John.
yep
John Frampton said:Which version (e.g. v10.x.y.z) of MicroStation are you using?
Any version prior to Update 14 or 15?
