Hi Guys,
i have a dgn file with another dgn as a reference where raster images are included.Now i want to print my geometry with this raster as a background from an layout model but in the pdf every raster image frame is drawn. (but i dont need them on my pdf)Interesting is when i print out of the normal model these frames will not be drawn.
But i have to use the created layout models because of mapsheet etc....
Maybe u can help me to get these frame sout of my pdf
Greetz and Cheers
Franco
Always a good idea to provide the software and version being used.
MicroStation Forum best practices
Franco Ponticelli said:i have to use the created layout models because of mapsheet
Is this a plain installation of MicroStation or possibly Bentley Map? Maybe it is another software package or tool?
Is this related to the output to PDF and what is being displayed there or is it in relation to how this is operating within the software? ie. this may be a Printing and Plotting issue.
I'm using a Microstation V8 Connect Edition and maybe it is a Printing and Plotting Issue...i don't know really ....Getting 2 results:
output from View-1 Top Model area...satellite image background without light yellow framesaround the tiles
and output from "Layout" area with light yellow frames around the tiles
i can't place screenshots here really (without URL) or?
Greetz
Franco Ponticelli said:I'm using a Microstation V8 Connect Edition
No such product! There's 32-bit MicroStation V8 and there's 64-bit MicroStation CONNECT.
Franco Ponticelli said:i can't place screenshots here really (without URL) or?
Use the Insert|Insert video/image/file button to insert a file or screenshot.
Hi Guys....the i will correct it to 64-bit Microstation CONNECT.
this is ouput with frames form model
this is output with yellow frames from layout/model
you see here the models:
when i print out of the first model …...no frames
all others…...yellow frames
Greetz Franco
The frames look like they are related to your legend. A legend is not part of MicroStation. Is that legend drawn manually?
Andrew Bell said:Is this a plain installation of MicroStation or possibly Bentley Map? Maybe it is another software package or tool?
Please answer Andrew's question!
