Need to Run Reports based on a selected set of items. Upgraded to Update 13 but don't have the option to set selection type in the Report dialog that was shown in https://communities.bentley.com/products/microstation/b/microstation_blog/posts/new-in-microstation-connect-edition-update-12---set-element-elevation . Are there limitations on when this is available?
I also looked in the Example project that installs with the program and don't see the Selection Type option in the dialog.
Kris Wishart said:Upgraded to Update 13 but don't have the option to set selection type
I just tried it and it worked for me. Update 13.1
I tried with a Selection Set and a Fence, which both succeeded.
I'm using 13.1 as well, and have tried it on 3 computers now with same result. So I am assuming there is some prereq or setting i am unaware of.
Found that the setting does exist if I look at the properties window but it doesn't show up in the report dialog. Not sure what to make of this.
