I am having some problem with Microstation connect, my references that are in 3d are going under my raster image in my 2d file, the only solution that I have found is either put the reference over the active design file in update sequence or export the reference to 2d. The reference file are contours, so they can‘t be above the active design file, then the contours lines are above everything. I can’t spend all day exporting my references to 2d, this did not happen in Microstation Powerdraft V8i.
The raster image is in background.
Hi Vilborg
Within the Raster reference dialog. there is an icon to the lft of the raster file link name. It has 3 small squares. This is the tool where you can tell the raster file to be behind or in front of the active file.
have you tried this?
Ian
My raster is in background, so I don´t know what is wrong, if I open the same file in Microstation Powerdraft V8i then the reference goes over the raster image and everything is fine, so I don’t know what I am doing wrong in Microstation Connection
Just to understand your workflow.
You have a 2d Design file that you are attaching 3d Contours to, along with attaching a raster image thru raster manager and putting it on the background plane.
Is there anything else you are doing ?
In the update sequence for the references, is the design listed last ?
Timothy Hickman
Main: 877 627 3772|
defect #1064558 filed for this issue.
Hi Tim
Any news on how far this defect is from a solution? We discover the same problem in MicroStation CONNECT update 15...
Best Regards
Rune Halkjær, LIFA A/S
