Unexplained increase in file size when creating new version of a dgn file.
Also one of the attached reference files in design view causes everything to run very slow, almost impossible to do anything when in sheet view.
Paul Hollow said:I am using dgnlibs for the levels. I’ve noticed that some levels stay black even though they are not being used, and it is not possible to delete them.
Hi Paul,
Have you check if your new created file from PW is placing shared cell's inside your new apparent empty file?
You can see under Cell Library and check Use Shared Cell box:
If something pops up and you want to delete it you can use the following key-in: "delete scdefs all" without the quotes.
José
