Hi everyone, i'm recently using microstation for some of our client requires it, i have no proper training in it so i hope someone could help me with the following questions.
1. could someone share how to batch convert a 3d to 2d, because i have alot of files to convert (actually it is suppose to be a 2d dwgs only but because there are some txt that has z value in it the program reads it as a 3d that was imported from autocad file)
2. please share also how to move the reference tblock together with the details inside it on the origin point which is 0,0,0 and also could be than as a batch process because of the numbers of the sheets that requires to be done.
Thank you in advance to everyone.
Carl Nhelee Angcaya said:here is for the first one coverting 3d to 2d
Have you looked at the links to MicroStation Help in my first answer?
Carl Nhelee Angcaya said: when i select the title block of my drawing (attached ref.) it shows that my x,y,z coordinates has a value instead of all 0's
Carl Nhelee Angcaya said:print screen of what i'm saying
That shows us what the title block looks like right now. Show us another screenshot after you've moved the reference manually to its correct location.
here is after i move the whole dwg manual to have it place in 0 origin.
yes sir i saw, ive already done that for one file, but is there a way to do it by batch since i have lots of files to convert.
Carl Nhelee Angcaya said:here is after i move the whole dwg manual
That's a screenshot of a different model. We can't compare 'before' and 'after'. Please post 'before' and 'after' screenshots of the same model.
