Hi
I have some cells (layouts) made in microstation v8i and I want to keep using them as layouts in ArcGis.10.2 or ArcGis Pro.
Thanks in advance.
MicroStation can attach shape files as references, but it can't create a shape file. You should take a look at Bentley Map, which can do that. There's a mapping Forum where you can find out more.
if you like to use the Microstation cells as ArcMap/GIS point styles for annotation purposes you can not do that. And you can not use them as ArcMap/GIS Layout graphics. I don't know any converter.
Frank
