What is the code to copy and paste from excel to microstation in a batch?
I have generated a excel sheet and now i want the data that is there in excel sheet to be copied into the microstaion (DGN file) at a particular position.
Can anyone help me through this?
You can even mail me on : saylib@tce.co.in
That may be beyond the realm of a simple batch process, since you are going between two applications.
You may want to see what the keyin:
OLECNTR INSERT; xy=0,0;xy=10,10
does for you. Edit the XY values to be what you like
MaryB
I suppose you should use KEYIN “PLACE TABLE FILE ”, TRY?
Work smart, not just work hard!
Sayli Baser said:What is the code to copy and paste from excel to microstation in a batch?
What version (e.g. v10.x.y.z) of MicroStation are you using? One answer above is incorrect if you're not using MicroStation CONNECT!
yeah, just using MicroStation CONNECT~
Grant Zhang said: just using MicroStation CONNECT
I'm not asking what version of MicroStation you use. We need to know what version the original poster (OP) is using.
